'13 WRX Mobil 1 ESP 5w30, 6,296 mi
Denver, CO
This is my third interval on M1 ESP 5w30, using the OEM Subaru blue filter. Mainly easy street driving, with a few autocross events. Car is still all stock engine-wise. Topped up twice (I like to keep the oil level at full), using about 0.5 qt Castrol Professional Edge OE 5w30 at one point and 0.5 qt RT6 at another point. The RT6 probably increased the viscosity a bit (the last two samples show viscosity retention of just M1 ESP). TAN seemed to increase faster, as compared to the last interval (TBN and TAN were about equal at ~6,600 mi).
I get this question a lot, but I picked this oil to meet Subaru's 5w30 and API SM/SN requirements for warranty, while having something a bit more robust than RC 5w30s. Subaru recommends 7,500 mi intervals for this model year.
Code:
Oil---------------------- Factory Fill ------ Edge OE 5w30---Pennzoil Platinum 5w30--- Pennzoil Ultra 5w30--- Mobil 1 ESP 5w30--- Mobil 1 ESP 5w30--- Mobil 1 ESP 5w30--- Mobil 1 ESP 5w30--- Universal Averages
Miles In Use 3,002 4,048 3,351 4,547 4,889 7,216 6,590 6,296
Miles on Unit 3,002 7,050 10,401 14,948 19,837 22,164 28,754 35,050
Date Changed 2/1/13 5/10/13 8/05/13 11/11/13 2/28/14 4/21/14 9/05/14 1/23/15
Make up Oil Added--------- 0 Qts. ------------ 0 Qts. ------- 0 Qts. ------------------ 0.6 Qts. ------------- 0 Qts. ------------ 1.0 Qts. ---------- 0.85 Qts. --------- 1.0 Qts.
Aluminum------------------ 7 ----------------- 9 ------------ 6 ----------------------- 5 ---------------------4 ----------------- 4------------------ 4 ----------------- 4 ----------------- 4
Chromium 1 1 1 1 1 1 1 1 1
Iron 34 16 14 11 10 13 10 10 9
Copper 27 9 7 5 3 4 4 3 9
Lead---------------------- 0 ----------------- 0 ------------ 0 ----------------------- 0 -------------------- 0 ----------------- 1 ----------------- 1 ----------------- 0 ----------------- 3
Tin 4 3 2 0 0 0 0 0 1
Molybdenum 1079 435 118 70 81 82 78 67 73
Nickel 0 0 0 0 1 0 0 1 0
Manganese 2 1 1 0 0 0 0 0 2
Silver-------------------- 2 ----------------- 1 ------------ 0 ----------------------- 1 -------------------- 1 ----------------- 1 ----------------- 1 ----------------- 1 ----------------- 0
Titanium 0 1 0 2 0 0 0 0 1
Potassium 2 2 2 1 0 1 0 5 2
Boron 198 26 6 60 126 105 93 67 46
Silicon 89 19 10 5 4 5 5 4 10
Sodium-------------------- 8 ----------------- 6 ------------ 1 ----------------------- 2 -------------------- 3 ----------------- 4 ----------------- 4 ----------------- 3 ----------------- 30
Calcium 2105 1777 2388 2422 1218 1235 1200 1153 1902
Magnesium 12 6 12 15 6 8 5 94 424
Phosphorous 892 680 725 798 695 714 715 706 832
Zinc---------------------- 1082 -------------- 802 ---------- 831 --------------------- 842 ------------------ 778 --------------- 855 --------------- 857 --------------- 835 --------------- 984
Barium 2 1 0 0 0 0 0 0 0
SUS Viscosity @ 210F------ 52.4 -------------- 66.1 --------- 58.9 -------------------- 57.3 ----------------- 62.8 -------------- 63.5 -------------- 64.3 -------------- 64.7 -------------- 56-63
cSt Viscosity @ 100C 7.99 11.91 9.91 9.44 11.0 11.21 11.41 11.52 9.1-11.3
Flashpoint in F 405 435 405 425 410 435 445 410 >365
Fuel
Antifreeze %-------------- 0.0 --------------- 0.0 ---------- 0.0 --------------------- 0.0 ------------------ 0.0 --------------- 0.0 --------------- 0.0 --------------- 0.0 --------------- 0.0
Water % 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0
Insolubles % 0.2 0.3 0.1 0.3 0.4 0.2 0.2 0.1
TBN N/A 2.8 N/A 5.2 3.0 1.5 2.2 2.5 >1.0
TAN----------------------------------------------------------------------------------------------------------- 2.2 4.6 2.3 3.5
I think wear numbers look awesome, especially including autocross events.
After much research I want to try M1 ESP 5w30 in my G37 next OCI. Not only it meets API SN for warranty as you had mentioned, it is an ACEA C3 oil with VW 504/507 and Porsche C30 approvals. Even MB 229.51, which this oil also approved for, is not as stringent as the other two.
The most intelligent argument I heard against using this oil was that it's designed for ultra low sulfur (
Nevertheless, from what I understand, running
Let me ask you. Do you feel/hear engine working harder during acceleration given this oil has HTHS viscosity >3.5cP? The reason I am asking is because I am currently running M1 0w40 with HTHS 3.8cP and the engine is not as peppy as with resource conserving oil. Plus my MPG dropped by almost 2.
That's significant mileage drop could not be caused by M1 0W40. Even if you use Europenian M1 10W60, I doubt that you see any difference. Did you change tires recently? Did you change gas brand? Did you check your tire pressure?
I have heard the VQs are hard on oil, like the Subaru EJ engines.
From my limited understanding, I think the TBN on this oil depletes much faster due to US pump gas (feel free to correct me if I'm wrong). My UOAs on ESP show that the TBN depletes quickly - I change my oil at 6-6.5k mi because the TBN seems low, although I'm happy with everything else and could probably go longer otherwise. It seems as though the ESP has a low TBN to start with, however.
Haven't looked at the datasheet for M1 ESP recently, but I'm assuming the HTHS is >3.5 due to the specs it meets. I ran a couple RC 5w30s before switching to this oil, and I noticed little to no difference at all in performance or fuel economy. I felt as though the car idled "smoother" on the ESP, but probably all in my head
I am glad you called me out on this, making me look more closely. It looks like MPG decline started to occur before M1 was in. Probably winter gas and colder temperatures making other fluids (diffs, transmission and tc) to impose additional drag.
There have been no modifications. Same tires, inflated to be at spec psi when ambient temperature is 20F, which is what we've been getting around commute times. Most of the time I fill up at the same Exxon stations, at the same pump. Sometimes at Shell. Always 93 octane.
From what I gather it's the lower Calcium content in these oils that contribute to relatively fast depletion in TBN, even though ACEA C3 oils suppose to start at TBN 10 or above.
I don't know if you had a chance to play around with this Lubrizol tool. Based on the specs the M1 ESP is approved for this oil is indeed top notch.
Oil Performance Comparison
