Goes to show people that the engineers designing the cars and recommending the drain intervals aren't nuts after all! I could probably run a good dino out to 10k miles in my Accord, which is what the manual suggests, but I'm not that ballsy.
Hey I helped a buddy with more than double that miles and he almost never changed the oil, only added to it for all the leaks in his Sentra.quote:
Originally posted by CastroPenzoHavoMobil1:
What's your horror story?
Today, I changed the oil in a friends car. The car (98 Ford Escort ZX2 w/83K miles) was driven 13,000 miles since it's last oil change!While not sure, I think the oil might have been Citgo 10w30 conventional. (The oil change reminder sticker had a phone number on it, I called out of curiosity and they said their bulk oil was Citgo 10w30)![]()
It was BAD!!! Once I popped the drain plug it looked like black paint oozing from the oil pan. It was all frothy and nasty. The dipstick had sludge on it. As I looked into the valve cover, it reminded me of the dark, sludgy crude you get when something greasy gets left on the stove burner for about 6 hours too long.
To make matters worse, there was only three quarts of oil in the crankcase when I drained it. Capacity is 4.5 quarts.
This is the worst first hand motor abuse I've seen! Remind me never to buy any used cars from this particular friend.
That called for a picture, man, come on, I know you must have thought about it, right....quote:
Originally posted by LarryL:
A long time ago, I took the valve cover off a small block Chevy and put it on the work bench. When I turned back to the engine the valve cover was still there. What happened was the valve cover had filled up with an oil film than had taken on the shape of the stamped steel valve cover and varnished over to a very slick looking finish that looked just like the valve cover. The 'Chevrolet' name could be seen just like the valve cover. I poked it with a screw driver and it cracked like glass. The whole area on top of the head was filled with sludge, except the area cleared by the rocker arms and pushrods.
In my shop class in high school, EVERY engine that was being rebuilt had to have the sludge scraped out with a putty knife from the, block vee, from the heads, from the oil pan. Back then, I thought that was normal.quote:
In shop class in high school we pulled apart some small block Chevies where the V underneath the intake manifold was completely filled with sludge.
