12BS AGM Walmart battery test
eastern NewMexico
Needed a battery for my stump grinder. After using the stump grinder for an hour or 2 it's really hard to pull start that 459cc engine.
Previous tests shows me that the 459cc engine only takes about 50 amps to crank over at no load. A little more to crank over the stump grinder clutter head.
I was at Walmart and saw a 12BS AGM motorcycle battery marked down half off because the box had gotten wet with water.
Snap on tester shows 263cca.
Not bad for a $30 battery.
