Concern about those aluminum threads is exactly why I'm considering this. I'm not worried about the plugs themselves- I'm reasonably sure that they'll be fine. My main goal is to avoid the plugs seizing in the heads: hence cleaning and application of antiseize.
With my Ford and GM engines, plugs cost about $2 each... so I'd replace them every time. Usually around 50-70k. But these Honda plugs are expen$ive (about $12 per plug). And I'm broke (starving-student and all that [censored]).
There are cheaper plugs available for this engine- for maybe $4 each... but they're cheap copper plugs, and this engine came originally with NGK iridiums. If this was an old Ford or GM engine, it wouldn't bother me a bit to put in some cheap plugs- but this thing is a modern aluminum engine with one coil-pack per cylinder and variable valve timing. That's old hat to some people but previously the most modern engine I've owned was a GM 3100. [censored], my truck still has a carburetor and a distributor.
Is anybody aware of actual plug failures in these engines (as in the tips breaking off or the like)? 'Cause if threads are the only concern here, then I'll probably antiseize and re-use these plugs. I mean, it's not like I'm towing a bass-boat with my Accord.
