1200hp turbocharged lsx oil
maryland
My engine builder said to use a quality 5w40 grade oil. I've ran some Castrol gtx for break in but now I'm looking to pour in some good stuff.it's a weekend toy that I take to the track. I'm looking at the Pennzoil ultra platinum 5w40 I run a Wix Racing filter as its the only one I've found that fits my remote mount oil filter housing. With the amount of use I'm looking for a once a year oil change
You would be served well by Pennzoil Ultra Platinum on an annual or bi-annual change.
Welcome to the board, got any pics of the beast?
As in Chevy engine? I bet you can't keep your foot in it for long that is some serious power.
For that much power im sure the turbo is putting out some serious boost. This is one where redline is a good choice, and at minimum id want high PAO for max oxidation resistance.
My turbocharged 351W Mustang wasn't as wild a yours, I was making "only" 2.2 HP per cubic inch.
I always ran Shell Rotella T6 5w-40 in that beast, and still would today if I still had it.
Originally Posted By: mjoekingz28
Nine years til his first post?
I've been a reader here for well over 10 years before joining
Rotella T6 5W-40
Tell us more about the LSX? Forged LQ4? What heads you running? Cam?
What turbo? Turbo headers or truck manifolds with v-bands? Trans?
Fbody?
Originally Posted By: Shannow
What's the definition of track, and for how long is the power down ?
Included the burn out and staging it's wot for 15 sec.
Originally Posted By: redhat
Rotella T6 5W-40
Fbody?
Gen 4 iron block, 237/242 115 cam, gt5588, th400 in a fox body.
Cool
Your motor, your oil choice. Magnetic drain plug. Magnet JB Welded on the filter can (heat resistance). Inspect both when you change. Any Fe metals stop before you need a whole motor ... UOA looking for high aluminum (piston skirts) and lead (bearings) ...
Rotella T6 5W-40
Fbody?
Very cool, notch or hatch fox? Love the notches.
I've got a Gen 3 LR4 in a Gbody, 87 Regal. Going BTR springs and pushrods, stock heads, plate an a Proform 650, MSD 6010.
