By the way, the 435s (6 bolt wheels) can develop a situation where the portal pumps oil into the diff thru the breather line, especially in the front.
"Von" on the benzworld forum has developed a relatively inexpensive fix for this. Have you driven yours enough on long distance high speed trips to be absolutely sure this isn't a problem? It's pretty easy to lose ~200ml of portal oil into the diff and destroy portal bearings and have a very bad day.
The fix is just a bit of metal tubing plumbing that attaches to the breather outlet and fill openings on the inner aspect of the portal box, just takes a couple of minutes to install.
Charlie
Charlie
