Originally Posted By: -SyN-
Switched to 5w30 in the Hemi with my summer oil change... She has been Silky Smooth and Very Quiet... No issues! Nor did I expect any...
After doing some researching around and reading... 10w30 just might be a better choice...
The Ram is a daily driver with mostly Interstate and Highway driving very little stop and go city driving and short trips are avoided as much as possible...
I live in Oklahoma so cold winters are not that bad but there are many days of 0*F weather... The Ram will be in the garage at night... Only at work will it be exposed to long periods of winter weather...
The 2 oils I am drawn back to are the 10w30 Pennzoil Platinum and Ultra Platinum...
These are the Pure Plus Version... I did not post the Ultra Versions..
SAE Viscosity Grade : 5w30
Density : 0.84 g/cm3
Flash Point : 224°C
Pour Point : -48°C
Viscosity @40°C : 56.9 cSt
Viscosity @100°C : 10.3 cSt
Viscosity Index : 170
CCS Viscosity @-30°C : 4,000 cP (-30)
MRV Viscosity @-35°C : 10,500 cP (-35)
Noack Volatility : 10.1%
Specifications : API SN, ILSAC GF-5, ACEA A1/B1, A5/B5,
Chrysler MS-6395, Ford WSS-M2C946-A, GM 6094M, GM
4718M, Honda/Acura HTO-06, dexos1
SAE Viscosity Grade : 10w30
Density : 0.843 g/cm3
Flash Point : 224°C
Pour Point : -48°C
Viscosity @40°C : 63.3 cSt
Viscosity Index : 150
CCS Viscosity @-30°C : 4,150 cP (-25)
MRV Viscosity @-35°C : 8,500 cP (-30)
Noack Volatility : 4.7%
Specifications : API SN, ILSAC GF-5, Chrysler MS-6395, GM
6094M, GM 4718M
My question is as stated above-->Is the 10w30 the better choice then the 5w30 for an owner who is using a 30Wt oil?
10W-30 and 5w30 are the same viscosity at operating temperature.
With this being said, 5W-20 is recommended for that engine for all temps according to Chrysler.
