10R80 Mercon ULV vs Mercon LV
USA
This is just a cautionary tale of using the wrong stuff.
2024 Ford Police Interceptor Utility (Explorer) 3.3L
This is my work car and it definitely gets its legs stretched on a usual shift. I'm at 60K and in the last few thousand miles the transmission started making some occasional weird shifts. Took it into the local Ford dealer and they couldn't replicate the issue. I wasn't surprised due to how randomly occasional these shifts were. I got the car back and had a couple immediate weird shifts followed by it shifting normal again. I'm guessing they cleared the transmission learning.
We usually don't do Transmission services on our cars but for this vehicle this time around I pushed for it. We had 3 2019 Tahoe's prior to this and between them we went through 3 transmissions, with mine needing another prior to it being sold. Most covered under warranty but lead to a long down time for these cars.
Had the local municipality shop work on the Explorer, change the transmission fluid and filter. After getting it back, I noticed something was immediately wrong. Gear shifts felt fine but a horrible grinding/squealing noise now accompanied the all the shifts. It would get somewhat better after highway driving but it obviously wasn't right. Took it back to the shop and figured out they used Mercon LV instead of Mercon ULV. Its now at an actual transmission shop waiting to get 16 quarts of Amsoil ULV pushed through it. Hopefully this didn't hurt the transmission too much...
I'm surprised how how intolerant these transmissions are between LV and ULV. DO NOT USE THE LV.
Agreed. I tried a D/F with LV fluid and it didn’t take well at all. It did do very well with about 2/3 ULV, 1/3LV, and 25% dose of lubegaurd red, plus adaptives reset. I know that sounds awfully specific but I was chasing down a problem and the dealer was useless.
The 10R80 has an incredibly soft,weak valve body-I’ve had 3 company Transits with 10R80s and NONE of them have shifted correctly nor smoothly once they hit 25,000 miles or so. If I was crazy enough to own a 10R80 equipped vehicle, I would be putting a Next Gen valve body in it yesterday!
Early changes and LG Platinum really make a difference in keeping the VB's happy. Once they start to get contaminated it is usually a downhill slope ending in a rebuild.
I've also never heard of a 10R making noise after a change. I think something else is probably not quite right.
I assume it was due to the thicker LV. Mechanic said everything else checked out. I did not myself check his work.
If I had to guess it was either severely underfilled, or overfilled. When you overfill a 10R it will foam the fluid go into a thermal runaway and cause all kinds of goofy things. Slow shifts, bad flares, etc.
Either that or it was underfilled and the pump was sucking air. That could possibly go away after the fluid heated up and expanded.
It isn't necessarily an LV thing. Yes, you should use ULV in the 10R's, but most of them will operate decently on LV, although not ideal, and not noisy.
Ill have to ask the transmission shop when I pick it up if it was over/underfilled.
With it making doing the weird noises while it was cold. Makes me wonder if it wasn't underfilled. I just immediately blamed the LV but your reasoning makes sense.
I doubt they'll be forthcoming if they made a gross error when they can just go ahead with the "right fluid" and cover their tracks.
Definitely interested in your updates. Thanks for sharing and checking in.
At 100C, the ULV is 4.5 cSt, and the LV is at 6.0 cSt. I don't know everything about the additive packages, but I suspect they are similar.
Is the theory here that the 1.5 cSt delta is somehow causing failure? That the oil is "too thick" for proper lubrication in the 10R80?
I'm finding that VERY hard to believe.
What is the differences of cSt at maybe 70*F? (cold start up) and not at full temp. I suspect that was why the the horrible noise was there and would later start disappearing. You very well could be completely right and they botched something else.
This is a government vehicle. Government owned shop found that they made a mistake with filling it with LV instead of ULV. Claim that level is correct though.
I took the vehicle to an actual shop that only specializes in transmission services. And they are aware of the problem I'm having. They would have no reason to lie about what it came in with.
Ask them to show you the burns on the back of their hand from checking the fluid level.
Otherwise, you're not doing it properly!
I'm only partially joking......
Exactly. A 30% change in operating viscosity is close to insignificant when the transmission will function with fluid that is 1000% thicker / heavier. It MAY make a noticeable difference but more likely it would take a dyno or accurate datalogging. I have a hard time believing that a mfg would design / engineer a transmission that would be so sensitive to viscosity outside of performance / formula racing.
