- Joined
- Dec 7, 2012
- Messages
- 3,574
Dad bought the 2016 Silverado in Florida. I called the salesman and got the invoice all straightened out and am flying down to Florida this Saturday and driving it back to Western New York.
Newer Silverado, 2013+ with 4.3
Once I am back, I already have all maintenance planned -- and all supplies purchased or on order.
Transmission
Will drop the pan, change the filter, add a drain plug and re-fill with new fluid. Most likely will drain and fill next spring.
Parts: ACDelco Transmission Filter 24236933, Valvoline MaxLife ATF
Engine
Change all (6) spark plugs, install new air filter, oil and filter change. Will probably hold off until next spring for a radiator drain and fill. Service in manual states 5yr/150k.
Parts: ACDelco 41-114 Professional Iridium plugs, Fram TGA8755A air filter, Valvoline SynPower 5W30 (with D1G2 labeling), Fram Ulta XG10575 (a yearly OCI will probably suit him well)
Brakes
Suck all brake fluid from the reservoir and fill with new, then bleed/flush each line. Will also visually inspect brakes. If they brake well on the trip back, I'll just pull them apart to lube them with silicone paste.
Interior
Install new cabin air filter and detail the ever-living snots out of this thing. It was a work truck so it is somewhat dirty, but I am super confident that with my Bissell Little Green machine and my mix of ajax/laundry detergent, I'll have the seats looking like new. Vinyl floor and plastics in truck will be easy.
Parts: Fram Fresh Breeze CF11809
Got some Winterforces for the steel wheels on the truck now to go through the winter. Will probably look for a set of 2001-2006 Tahoe Z71 wheels for the summer .
Then Dad can have his truck. Want it all clean and up-to-snuff before it goes into his DD routines.
Transmission
Engine
Brakes
Interior
