1/4 to 1/2 quart underfilled dexron vi any problems?
Hey guys I have a 4l60 in my truck and I did a pan drop and also exchanged the fluid through the cooler lines so I got all 12 quarts exchanged. I ensured the pan gasket was seated good and I did each pan bolt to 10 foot lbs with torque wrench. I ensured the transmission cooling line was tight and fit properly. Before I drove the truck I made sure it was at the correct fluid level cold and then I drove 20-30 mins and shifted between all gears and checked the fluid again and had to add some probably about ¼ quart ish and maybe upto ½ quart maximum I added. I was on a pretty level surface and then i locked the dipstick in place and drove home. The next morning, I started the truck and everything was normal and I hit the road on the highway for 6 hours but I stopped a bunch of times and noticed nothing with the transmission. And then a couple days later, the temperature was noticeabley colder in my city and I started the truck and I noticed when I switched from park to reverse and reverse to drive , the rpm would rev up before going into gear. I thought it was just due to the cold weather or something and then i hit the road and after driving 100 km on the highway I pulled over to fuel up and also check the tranny fluid level incase I needed to add some more. I switched it into every gear and then did the check. The tranny was obviously hot and when I went to check the level was at the cold position. I checked again and ensured the level was at the cold position again which kinda freaked me out. I added probably about ¼ quart ish maybe a little bit more to get it to the hot section on the dip stick and drove the rest of the trip on the highway. Ever since I filled the fluid, the tranny has been normal. No rev ups when I shift and nothing else.
My question is did I do any damage? ¼ quart - ½ quart underfilled is barely any fluid but it seems like my tranny is very sensitive. Does this obviously mean I have a small leak somewhere? Or could there some other reason that I lost .25 quart of fluid over a couple days of driving? Before I did the fluid exchange and pan drop I checked the fluid color and it was red and not burned so I know it wasn't too late for my tranny. It just seems super weird that I lost some fluid and that the fluid loss caused rev ups and weird tranny operation when cold.
Thanks!
FWIW, it happened to me the first time I replace ATF in my Camry.
When I started driving it the next morning, it was surging.
I thought I damage the trans, so I brought it to my mechanic.
All he did was top the fluid.
I drove the car for another > 100k miles before I sold it.
As far as damage, you will never know unless you open it up and measure everything with a caliper to see if there is any wear or do an oil analysis.
Probably no damage to the trans.
The damage that can happen with low fill levels or failing bands & servos is
damage to the thrust bearing holding the crankshaft, the intermittent slamming
into gear can end up putting fine particles in suspension in the crankcase oil of all places.: (
You probably did none of that just 1/4 quart shy of full.
thanks for the reply and thats true but i feel like .25 to .5 quart is nothing in like a 6 quart pan and 12 quart system. but i aint a tranny tech
