at some point you guys need to just drag the air line over. these things are getting more and more ridiculous
goteeeeeeeeeeemIts only as versatile as the hose is long.
It's rare that anyone needs as much power as a 2235timax. Usually it is only for 1 or 2 fasteners.Its only as versatile as the hose is long.
I am cautious about using a breaker bar. I used one on some lug bolts on a boat trailer and snapped two off. A machine shop used a milling machine (I think) to remove the broken off lug bolts. I think an impact wrench would have gotten them out.I look at cordless as a welcome addition to my air tools not a replacement for them. I just had to remove a wheel on the Kubota yesterday down in the back, I would have had to drag over 150 feet of air hose out there or use a breaker bar, the mid size Makita took them right off.
My current method is to hit a rusty lug nut with PB Blaster. Then try and get it off with an impact. If it does not come off with a little work on the part of the impact wrench, then I come back the next day with more PB Blaster and try again. In some cases it has taken a few days, but I get them off. Patience is a lot easier than snapping off a lug bolt or stud.I am cautious about using a breaker bar. I used one on some lug bolts on a boat trailer and snapped two off. A machine shop used a milling machine (I think) to remove the broken off lug bolts. I think an impact wrench would have gotten them out.
I use both but I LOVE my cordless impacts and they serve 99% of everything, even in the shop where air is readily available.
I don't understand why guys want to make it an air vs battery thing. They can co-exist and complement each other.
On a BJ press doing u-joints the control of cordless is superior -- you can blip it forward or back a touch MUCH easier. The inherent speed of air gets away from you, esp backing off.
But in tight quarters I grab my Astro Nano pneumatic.
For those who don't like change, don't be threatened! We won't mandate you buy a cordless impact!
Bless you for not mandating.I use both but I LOVE my cordless impacts and they serve 99% of everything, even in the shop where air is readily available.
