Here is my used oil analysis of Amsoil Signature Series 0W-20 in a FB-series motor for a 10K mile interval:
Html:
Vehicle 2012 Subaru Impreza Sport Limited
Engine Subaru FB20 - 2.0L H4
OIL AMSOIL Signature Series 0W-20 (ASM)
TOP-OFF OIL None - No consumption.
FILTER FRAM - XG7317
SUMP CAPACTIY 5.3 QT
MILES IN USE 10K
MILES ON UNIT 87K
SAMPLE TAKEN March 7 2015
LAB: Oil Analyzers Inc.
Wear Metals (ppm):
ALUMINUM 1
CHROMIUM 0
IRON 8
COPPER 1
LEAD 0
TIN 0
CADMIUM 0
SILVER 0
VANADIUM 0
NICKEL 0
Contaminant Metals (ppm):
SILICON 24
SODIUM 9
POTASSIUM 0
Multi-Source Metals (ppm):
TITANIUM 0
MOLYBDENUM 155
ANTIMONY 0
MANGANESE 0
LITHIUM 0
BORON 70
Additive Metals (ppm):
CALCIUM 3428
MAGNESIUM 23
PHOSPHORUS 681
ZINC 770
BARIUM 0
Contaminants:
FUEL DILUTION
SOOT
WATER
Fluid Properties:
cSt @ 100 C 9.0
TBN 3.83
OXIDATION 56 abs/cm
NITRATION 16 abs/0.1mm
Here is a 6.5K mile sample:
Html:
FILTER Mobil1 M1-104
SUMP CAPACTIY 5.5 QT
MILES IN USE 6.5K
MILES 73.1K
SAMPLE TAKEN 08/18/2014
Wear Metals (ppm):
ALUMINUM 0
CHROMIUM 0
IRON 5
COPPER 1
LEAD 1
TIN 0
CADMIUM 0
SILVER 0
VANADIUM 0
NICKEL 0
SILICON 25
SODIUM 6
POTASSIUM 0
TITANIUM 0
MOLYBDENUM 157
ANTIMONY 1
MANGANESE 0
LITHIUM 0
BORON 96
CALCIUM 3729
MAGNESIUM 44
PHOSPHORUS 716
ZINC 803
BARIUM 0
Contaminants:
FUEL DILUTION
SOOT
WATER
Fluid Properties:
cSt @ 100 C 9.1
TBN 6.27
OXIDATION 51 abs/cm
NITRATION 11 abs/0.1mm
Mobil 1 Extended Performance is similar to Amsoil Signature Series and you should be able to run it for at least 10K. Just make sure you do a used oil analysis to verify.
Html:
MILES IN USE 10K
MILES ON UNIT 87K
Wear Metals (ppm):
ALUMINUM 1
CHROMIUM 0
IRON 8
COPPER 1
LEAD 0
TIN 0
CADMIUM 0
SILVER 0
VANADIUM 0
NICKEL 0
SILICON 24
SODIUM 9
POTASSIUM 0
TITANIUM 0
MOLYBDENUM 155
ANTIMONY 0
MANGANESE 0
LITHIUM 0
BORON 70
CALCIUM 3428
MAGNESIUM 23
PHOSPHORUS 681
ZINC 770
BARIUM 0
Contaminants:
FUEL DILUTION
SOOT
WATER
Fluid Properties:
cSt @ 100 C 9.0
TBN 3.83
OXIDATION 56 abs/cm
Html:
MILES IN USE 6.5K
MILES 73.1K
Wear Metals (ppm):
ALUMINUM 0
CHROMIUM 0
IRON 5
COPPER 1
LEAD 1
TIN 0
CADMIUM 0
SILVER 0
VANADIUM 0
NICKEL 0
SILICON 25
SODIUM 6
POTASSIUM 0
TITANIUM 0
MOLYBDENUM 157
ANTIMONY 1
MANGANESE 0
LITHIUM 0
BORON 96
CALCIUM 3729
MAGNESIUM 44
PHOSPHORUS 716
ZINC 803
BARIUM 0
Contaminants:
FUEL DILUTION
SOOT
WATER
Fluid Properties:
cSt @ 100 C 9.1
TBN 6.27
OXIDATION 51 abs/cm
