Originally Posted By: Triton_330
Originally Posted By: midnytwarrior
Hello guys,
Apologies for the late response. I just came home from work.
Wow! I'm totally overwhelmed by the replies. I really appreciate it guys! A whole lot of new things I just learned.
Anyway, for the oil, yes, it's a 5W-20 fully synthetic oil, API SN, ILSAC GF-5. it used to have a Dexos1 logo on the bottle but it's now gone. I asked our top management about the Dexos1 logo and they said their license had expired, and the oils we have (5w30 & 5W-20) still contains the same formulation, and until now they are hesitating to renew the Dexos1 license due to it being expensive.
The oil filter used was an AC-Delco PF48.
Our Area Manager then met with the technical engineer from the dealer and the engineer told him that only 0W-20 is to be used and no other viscosity. Otherwise, warranty claims would be denied.
We then checked with our lab engineer and this is what he stated(pasted):
Quote:
Newer engiens are made to VERY VERY exacting tolerances inside them and they REQUIRE the new synthetic 5W_20 engine oils to match the small spaces between rings and engine bearings. The NEWER "0" series oils are JUST a bit better and more refined, and protect the engine at start-ups in the MOST cold weather only, and also can be a WEE bit more fuel efficient. As far as I have been told or read, ALL 5W-20 oils are synthetic or partial synthetic oils. 0W-20 is Full Synthetic and will actually get you MORE power and fuel mileage with time, and SOON many oils will feature this NEWER oil as a standard for fuel economy. It is AHEAD of it's time in many ways
So, we where surprised about his response which did not even tackle anything about the issue. (Actually we were expecting him to say "OK, there's no issue with 5W-20 vs 0W-20 etc, but he just copied it from API)
Thanks again for the support!
According to the Owner's Manual:
https://www.chevrolet.com/content/dam/Ch...ners-manual.pdf
It is true that this vehicle requires 0w-20 only:
Click to reveal..
But, I also found something else interesting...
See what I bolded in your quote? You said they used a PF48...
The manual states to use the PF63 oil filter:
Click to reveal..
It could be the oil filter causing the noise.
~ Triton
I guess it is best to inform all branches to be aware of the recommeded oil. We still don't have a 0W-20 grade. And I'm hoping that this issue would make our plant engineers to manufacture or the sales department to acquire a different brand but with the 0W-20 viscosity otherwise, we would be losing a lot of customers.
Thank you for the manual.
