Originally Posted By: 901Memphis
If you really want to try a top 0w20 you should go to a Toyota dealership and score some TGMO 0w20. Bring your empty jugs and get them filled or buy the single quarts if you want to pay for them. TGMO is much lighter at all temperaturestthan AFE 0w20.
If TGMO 0w20 doesn't give you a fuel economy boost the AFE surely won't. It might be a couple bucks more than AFE, but if it saves you gas you might come out ahead.
Yes, it is much lighter and is an OEM lubricant that doesn't carry any recommendations for Ford or GM applications, unlike the Mobil products (AFE and EP) which BOTH carry recommendations for Ford and GM applications that spec 5w-20 and 0w-20:
http://www.mobil.com/USA-English/Lubes/PDS/GLXXENPVLMOMobil_1_0W-20_Advanced_Fuel_Economy.aspx
Quote:
Mobil 1 0W-20 Advanced Fuel Economy is recommended by ExxonMobil for SAE 5W-20 and 0W-20 applications in all types of gasoline fueled passenger cars, SUV’s, vans, and light trucks.
Quote:
Mobil 1 0W-20 Advanced Fuel Economy meets or exceeds the requirements of: Ford WSS-M2C947-A
Mobil 1 0W-20 has the following builder approvals: General Motors Service Fill dexos1™ (license number GB1D0415015)
http://www.mobil.com/USA-English/Lubes/PDS/GLXXENPVLMOMobil_1_Extended_Performance.aspx
Quote:
Mobil 1 Extended Performance meets or exceeds the requirements of: Ford WSS-M2C947-A
Mobil 1 Extended Performance has the following builder approvals: dexos1™ (license number GB1D1009015)
And neither oil is likely to yield a perceptible increase in fuel economy over a conventional 5w-20, certainly not enough of one to pay for the difference in price between something like Pennzoil Conventional and TGMO/AFE/EP.
The only way the more expensive oil would pay for itself would be through extended drains. Or if the OP lived in Edmonton, Alaska or the Yukon and could actually benefit from the better cold flow characteristics of the AFE/EP products.
It's great Mobil says Mobil 1 Advanced Fuel Economy 0w20 meets/exceeds Ford WSS-M2C947-A, but if your Ford specs 5W-20, the relevant standard is WSS-M2C945-A. While Mobil offers a generic statement that its 0W-20 is appropriate for 5W-20 applications, they don't say it meets the ...945-A standard. Wouldn't take much space on the PDS to do so, leaving some of us under warranty to wonder if it's a risk.
