I don`t know whether this has been before-found some interesting info about Fiat Powertrain/Infineum/FL Selenia-Petronas co-operation in developing a SAE 0w-20 HD FE oil.
The first publication is from Lubes'N'Greases, 2008...page 18:
http://www.lngpublishing.com/LNGmagEMEA/LNG_july2008.pdf
Visc.@100C -8.6cSt;HT/HS-2.9cP...
Quote:
...declined
to disclose formulation details
except to tell the TAE
symposium that the 0W-20
version uses API Group IV
and Group V base oils...
...The engine tests did reveal
slightly increased wear on
some components in the valvetrain
– exhaust rocker arm
bearings, injector rocker arm
bearings, camshaft bearings
in the cylinder head – but
still well within the normal
acceptable limits. All the testing
was carried out in standard
unmodified engines,
showing that good engine
design enables the use of very
low viscosity lubricants...
Hints about the ongoing development of the lubricant are given in some other documents...like this one from Infineum(dated 2010):
Delivering the Lubricant Performance...
A fuel saving comparison chart from,Cursor 13 engine:
Quote:
...declined
unmodified engines,
