Are thin oils the best cleaners of all?
Found this tread from 2003 which references a Mitsubishi TSB. Fill with Mobil 1 0w-20 and run at high idle for 30+ minutes to relieve stuck lifters in one of their engines. Surely there were oils with more detergency available. Not to mention the multitude of crankcase additives on the market. Yet the recommendation is to go thin. Perhaps all the sludge prone owners out there should run this viscosity full time if their car allows the spec?
Here's the original quote:
Originally Posted By: Dr. T
The cleaning ability (especially acute cleaning) comes from it's "thin" viscosity. ie. a TSB for Mitsubishi engines which exhibit stuck valve lifters is to drain oil and fill with Mobil 1 0w20 and run for high idle for 30 min. or something in order to clean out sludge/varnish....and then replace with regular oil...
