I think you would be fine. I always use another oil in my machines,ATVs,motorbike, & snowmobile. They give you such an oddball spec with that 2w-50, just to throw you off I think.
Since you are in AL, your using it on the warm side I would think.
I also have another technique that may not be approved at BITO-guy headquarters. That would be blended oil of the same type. In your instance you could put in a quart of 15w-50 & another of 10w-40,or even 5w30. They would both be the same oil, Mobil 1 or whatever with the mix depending on your quantity. You would want to factor in how you drive & expected temps.
