My brother's '09 Accord is coming up on 30K miles and I wanted to flush the ATF right. The Honda way is 4 drain and refills and going through the gears and locking up the converter 5 times between drain and refill (or you could drive the car around). This seems very time consuming, uses 12 qts of ATF, and no one really does all that.
Quote:
NOTE: The term “flushing” refers to repeatedly draining and refilling the trans with Honda Genuine ATF-Z1. Don’t confuse it with aftermarket flush systems. American Honda still strongly recommends that you avoid using them on any Honda vehicle. The original procedure was written for simpler A/Ts that readily upshifted when you ran the vehicle on a lift. But A/Ts have come a long way since then, and most of the newer ones balk at shifting past 2nd gear when on a lift, unless you work the shift lever a certain way. In light of all this, we thought it was high time that the A/T flushing procedure got a facelift. So here’s the latest word on flushing that works for all A/Ts:
1. Set the parking brake, and raise the vehicle on a lift.
2. Drain the trans, and refill it with Honda Genuine ATF-Z1. Refer to the applicable S/M or to ISIS for details.
3. Start the engine, shift into Drive, and release the parking brake.
4. Push down on the accelerator pedal to raise the vehicle speed to 2,500 rpm.
• If the trans shifts past 2nd gear, go to step 5.
• If the trans won’t shift past 2nd gear, keep the engine speed at 2,500 rpm and shift from Drive to Neutral and back to Drive. Then go to step 5.
5. Make sure that the trans shifts through all the forward gears and goes into torque converter lockup.
6. Let off the accelerator pedal, and press the brake pedal to drop the vehicle speed to zero. Shift into
Reverse and then into Neutral.
7. Shift into Drive, and repeat steps 4 thru 6 four more times.
8. Set the parking brake, and repeat steps 2 thru 6 two more times.
9. Drain the trans, and reinstall the drain plug with a new sealing washer.
10. Refill the A/T with ATF-Z1.
The other way is to flush out the cooler line. This seems like it'd be a lot faster and would only use about 6 qts ATF.
What I wonder is why does Honda think you need to go through all the gears and get converter lock up to fully distributed the ATF? Doesn't this suggest that just running fluid out of the line doesn't really distribute the fluid fully and won't get a full flush. I always believed a line flush did get most of the fluid out.
Also I think there is an inline filter on these ATs with a small paper element sealed inside. I know most don't get changed. It seems like you'd want to change it regularly. Also I'm just going to go with ZL-1, but I'm getting ahead of myself now.
