went to clean the throttle body today on a new to me 08 Honda Pilot 166,000 miles, SE, AWD. After I cleaned it and the air box, I went ahead and took a look at one of the transmission solenoids as I'd read on here the little metal screens get clogged and need to be cleaned. I'm halfway there disassembly wise so I went ahead. I found a little build up but not bad for 167,000 miles. I put it all back together and went to take it for a test drive and I was sick to my stomach. The trans was shifting hard and shuttering between what I think is 2-3 and 3-4th gear. I had a CEL pop on immediately after starting the vehicle before even leaving. It has the yellow triangle and engine emblem illuminated as well as the "VTM-4 VSA". A code scan showed P0108. So I double checked and found I had left the MAP sensor cable disconnected. That connection fixed the shudder and cleared the dash lights except the engine icon. I then used MAF sensor cleaner to clean the MAP sensor.
Well, the vehicle runs fine now, except the engine CEL is still illuminated and it seems my code reader will not clear the code. I don't know if the vehicle is preventing the code from being cleared or just what. It doesn't even go off for a second when I attempt to clear it.
So, Same code, car runs fine, CEL still on. I'm unsure of what to do next. Can I use a multi meter to test the MAP sensor?
Your assistance is appreciated.
