My 08 Mini Cooper Clubman S, I noticed the coolant expansion tank is empty. It has minimum and maximum lines but there is nothing in the tank. The car is low miles (34k). I noticed the other day after driving it for a short s distance on the highway that there was water under the driver’s side of the engine on the parking lot ground. I went back and checked the spot and the water had evaporated up and left no stain so I figure it was only water and not coolant. I’ve never seen any water or coolant leaks in my garage after driving it. I’ve been given advice to try adding tap water to the expansion tank. Should I do that or just take it in to a shop for it to be checked. If I do add water, won’t that mess up the coolant ratio?
