07 Chevy 2500HD ~300k opinions
The truck looks great!
Just a thought, but could the hydroboost be leaking into the interior of the truck? Just a drop or two of fluid could make it smell.
Smells outside more than in, could be leaking buy not making it inside. That might be a fall project!
The truck cleaned up nicely.
Does it still have all of the exhaust manifold bolts?
Guessing by what I heard today negative! Might get the dorman clamps like I did for the other.
This truck is 50/50 on if it was maintained good. Took over 10 pumps or more and water came out of a couple. On ball joint wouldn’t take anything, managed to drill/clean it out and finally did. Only one ujoint had a zerk, the other two didn’t look old. This and Express has the same amount of zerks, my least favorite job times two now.
New steering bearing worked awesome.. no annoying constant rattle and no wandering. Might not need a steering box. Someday will get the $100 metal version. Also new fan clutch worked. Too quiet now 😂 can hear the tires. Has Goodyear Wranglers which isn’t old but one has dry rot, the others look ok. Walmart’s Dexetros might be in its future.
What's up with that sidewall? Maybe a belt twisted or something? The cracking wouldn't make me nervous, but the sidewall shift does. Good idea on the new tires.
A few posts up you mentioned the mileage. 12-13 seems pretty normal for these trucks unloaded. My 2012 with 3.73 gears would only break 13 mpg on easy country roads, unloaded, cruising at 50ish in mild spring or fall weather. Any change to that exact condition would drop the mileage.
Hey the milestar Patagonia LT all terrains you can get from discount tire have been surprisingly excellent on a friends f150. I don’t generally go for cheaper tires, but these have been quiet, aggressive tread, long lasting, smooth, and hes building his own house with it. Tires have been excellent. If you are looking for a solid, budget tire, they are made by linlong I believe and are holding up very well.
I was so glad my JL Rubicon didn't come with the stupid red dash they offered. It was simply trying too hard to be "cool."
That said, OP's situation is sentimental and very different.
I have that dash and it’s not stupid - the lady in there is stupid!
(and the navigation couldn’t find a barn on a 5 acre farm) 😵‍💫
Forgot about this thread, paid for the truck yesterday and a really good price. I have alot of wiggle room for repairs and not throwing money out the window. Hoping it can be the heavy farm hauler for the next 10-20 years and probably no more than a 100k. Overall seems well maintained and mostly highway miles.
Parts show up next week, really curious to know the oil pressure 😂. Oil is consistent in color with our 04 6.0L. So many repairs planned but already have practice on the 04’s. Going to lube the slip yoke and see if it fixes the take off issue. Have a heavy duty fan clutch coming, this one is on all the time and has to be the reason for 12-13mpg. Maybe not but still not good. Transmission is slowly going to get Dex VI, going to try vacuuming it out a couple times before dropping the pan. Still a little red and temps were fairly low.
The debate is the dash.. I think I’ll leave it as a tribute to the previous owner since shes longer with us.
I’d do one extraction flip - with a bottle of LG red in Dex VI - and then get after all the other things you plan …
Think they all have one on the sidewall, not a fan of Goodyears. Has the GT5 axle so 4.10's so yeah it might be maxed out.
Was thinking originally Dextros but now might go even more aggressive that Patagonia's. Just on the rears, old school farm truck style. Might try to find a G80 axle next year.
Have bottle red ready.. The 4l80e in the RV still shifts amazing at 120k with it and Dev VI, at 27k when we got it the fluid was burnt and had a slow shift.
  • Like
Reactions: 4wd
And it has oil pressure! Warm and idle. The new sensor came with a screen but there wasn’t one there so didn’t use it. Now hope I got it tight enough.
The Dakotas ps cap on the left, Chevys on the right. Thought it was missing a piece. Put the Dakotas on it see if it helps.
the 06.5 or 07 classic is regarded as the best truck ever made by gm....but all machine have their limits. snd the hour meter is very wrong.
if it rides drives and shifts good, it could not have got that far without maintenance
I've been down in OBX the last day and I'm filled with joy with the amount of GMT800s on the road around here.
This MO boy had to look that up.. North Carolina?
Got the coolant flushed and I can say it was well maintained. Way more orange than I thought. Should of replaced the reservoir but got it cleaned sorta. Didn't think to bring hose clamps or would of eliminated the plastic quick connects. I'll do that sometime shortly. Also got the oil changed and replaced the oil cooler gasket. Alot of build up around it but probably was the rear mail seal. Not sure if the new oil gasket was a good idea, the factory one had o-rings around each port the Fel-Pro doesn't. Oil pressure is a little higher after the change. Procrastinating working on the brakes, tempted to hold off and order new hoses.
