'06 Tundra Rear Diff Blackstone Report
Southern Indiana
This is the report for my 2006 Tundra rear diff.
This is the original factory rear diff oil.
Mileage was 18,500.
Replaced with Amsoil 75W90 SVT w/Amsoil Slip Lock Additive.
My Tundra has the Limited Slip rear diff.
It is not an electronically controlled diff.
[image]
[/image]
I will go up to a 2,000 miles .The oil still gets real bad looking when I change it again in a year . After that the oil seems cleaner when doing the recommended or longer oil change intervals
Is it me, or are there used oil analysis popping up everywhere except the used oil analysis section?
I too believe that factory fill should be dumped at a reasonable mileage and upgraded if possible. A simple removal of initial break-in wear is smart.
I've pulled fluid from various Tundra/Sequ 'ends. It never looks good and the drainplug magnet always has a 1/2 peanut seed sized dome of metal powder along with occassional metal splinters. Makes me wonder if 110wt would be a better choice, and definitely a no-brainer if the truck is worked.
18k miles is a pretty low run. Iron is nuts but normal for factory fill.
Diffs. with 85/140 look the same .
It will be much lower from here on out. This is why people in the know change out transmission fluid,T/Case and diff fluids at 10,000 miles from OEM. Gears wear in much more then an engine could ever hope to the first 10,000 miles. You should see how hot a new vechiles rear diff can get going 70-90MPH onthe way home from the dealership!!! The only way around this is to spend a lot of time lapping the gear that mesh like the ring and pinon.
good thing i dont buy new cars haha.. but thats a good rule of thumb to switch everything out before 10k miles. just remember if its under warranty to follow warranty regulations and you should be ok
Thanks for the report. I got the same 06 truck also with LS. The 438 of iron is interesting. Not much of a base to judge if this is normal or not. I suspect its not bad for a 1st oil change. I guess Toyota's recommend 15,000 mile OCI for the limited slip differential is probably a good one. I'm going to change mine soon and thinking about trying one of the new XXw-110 if I can get it locally. If not I may try a XXw-140wt on advice I'm getting from a local Differential/ manual transmission expert who is telling me to go heaver than XXw-90Wt on this rearend in the Tundra with the V8 for best durability. He has done good work for me over the years on Muscle cars so I respect his opinion.
In my 06 manual it specifies a synthetic 75w 140 for the standard differential (non LS). It also goes on to state a straight 90wt above 0 degrees F for the mechanical limited slip differential. Mine has the mechanical limited slip.
