- Joined
- Dec 30, 2006
- Messages
- 29,558
What`s the major differences between Amsoil Severe Gear 75W90 and Amsoil Gear Lube 80W90? My car`s rear diff specs an 80W90 per owner`s manual and FSM. Does Severe Gear have the same limited slip additive as the Gear Lube? Reason I ask,is that when the time comes and I do a rear diff change,should I stick with the tried and true Gear Lube 80W90? I drained the OEM fill (Pennzoil 80W90)and tried a synthetic 75W90 one time and got bad rear wheel hop........replaced it with the Amsoil 80W90 Gear Lube and it immediately went away. Some Z32 owners report diff whine if you use a 75W instead of an 80W.
What`s the experts` thoughts?
