This is my first UOA post so please comment on this!! I used a very short OCI b/c it is my first UOA report and was just curious to see how the truck is wearing.
Engine Make/Model: 2006 Nissan Titan V8 5.6L
Oil interval: 2569 miles
Engine mileage: 11634 miles on odometer
Oil/oil filter used: 6.5 qts Mobil1 TSUV 5w-30 SM & PureOne
Makeup oil: none
Oil lab: Blackstone
Oil samples was taken on 5-24-06
Aluminum: 2
Chromium: 1
Iron: 6
Copper: 2
Lead: 2
Tin: 0
Moly: 75
Nickel: 0
Manganese:0
Silver: 0
Titanium: 0
Potassium:0
Boron: 38
Silicon: 12
Sodium: 8
Calcium: 2173
Magnesium:11
Phosphorus:571
Zinc: 672
Barium: 0
TBN: 4.8
SUS viscosity@ 210F: 59.1
Flashpoint: 390F
Fuel: Antifreeze: 0
Water: 0
Insolubles: TR
Blackstone's comments: You have successfully past wear-in at 11634 engine miles and your engine is doing delightfully well using this type oil with the conservative oil run. The TBN was 4.8 so feel free to add miles to the oil use next sample. Try a 4500 mile oil use run. Universal averages show typical wear metals for an oil from this type engine after about 4790 miles run on the oil. Air and oil filtration appear normal. This was 5w/30 engine oil with no gas, moisture or anti-freeze in it. We doubt wear in the next sample will show much changed. This is a very nice wearing Nissan!
My comments: Although i think this is a good report, i think i can do better by switching to GC which i'm currently on and will do another UOA of. My silicon and sodium appears to be a little high? I've used PureOnes and Havoline for the first initial 5000 miles and switched to Mobil1 TSUV 5w-30 after that. I also switched out my OEM air filter at 6000 miles with a Wix air filter.
Makeup oil: none
Oil lab: Blackstone
Aluminum: 2
Chromium: 1
Iron: 6
Copper: 2
Lead: 2
Tin: 0
Moly: 75
Nickel: 0
Manganese:0
Silver: 0
Titanium: 0
Potassium:0
Boron: 38
Silicon: 12
Sodium: 8
Calcium: 2173
Magnesium:11
Phosphorus:571
Zinc: 672
Barium: 0
TBN: 4.8
Flashpoint: 390F
Fuel: Antifreeze: 0
Water: 0
Insolubles: TR
