RTV on exhaust parts? Hell no. Use proper exhaust sealant.He asked me to reinstall the assembly and smear a bit of Permatex Ultra Copper onto the donut gasket for extra sealing.
Hey @The Critic I now own an 2008 Corolla and working on a 2007 Corolla, they have this exact same issueIt has been more than 2K since this mickey-mouse repair was performed. Surprisingly, the repair is still holding up.
Something like this would have been my first attempt to repair it as well. Either that or infill with some (epoxy?) or something that's heat resistant, then smooth out (to restore to original dimensions) and use a gasket with some sort of sealant.Their "cleaning" resulted some of the damage but it did widen out the flange a bit. He asked me to reinstall the assembly and smear a bit of Permatex Ultra Copper onto the donut gasket for extra sealing. I can't say I am a fan of this fix, but I complied. I will allow the RTV to cure overnight and recheck in the morning. If the repair fails, he asked me to bring the car down for them to weld on the new flange.
Local muffler shop gave me one from an old catalytic converter that was still in good shape. It is on my to-do list to get it welded.Hey @The Critic I now own an 2008 Corolla and working on a 2007 Corolla, they have this exact same issue
Your link for the exhaust donut flange doesn’t seem to work, were you able to find one to be welded or is your temporary fix still holding?
I would like to buy just the exhaust donut flange and get them welded if possible
Any overall suggestions? @Trav and @The Critic
the whole Cat or just the exhaust flange portion?Local muffler shop gave me one from an old catalytic converter that was still in good shape. It is on my to-do list to get it welded.
The RTV fix actually held for over a year until I had to raise/lower the engine to replace the lower control arms; that was when it unsealed itself.
Just the flange.the whole Cat or just the exhaust flange portion?
Hope you’re still on the forums.. i’m having the exact same issuesJust the flange.
Hope you’re still on the forums.. i’m having the exact same issues you faced..View attachment 85206
Well, muffler guy’s recommendation worked. At least for now.
Fixing this exhaust leak also resolved my fuel trim issue since Toyota uses the rear o2 for fuel control. Trims went from +14 to +8, almost immediately.
He is selling me the spare flange for when this bandaid repair fails, which I’m sure it will.
I used a cone adapter thru the exhaust pipe.How did you smoke test the flange to see it was leaking? When you fixed the flange your ltft immediately dropped?
