I just found out today that my 04 Ranger has been recalled. They put the wrong fluid in the auto transmission at the factory.
Ford only uses Mercon and Mercon V, so I'm guessing that they put Mercon in?
I called the dealer and they said all I need to do is come by and they will add 1 pint of an additive that will "FIX" everything.
I only have 8,000 miles and at 3,000, I installed a drain plug and replaced the filter. Dropping the pan only lets out about 2.5 qts of fluid. I put in Motorcraft Mercon V. Last week, I changed the oil, went ahead and pulled the plug on the transmission pan and drained another 2.5 qts of fluid. Again replaced with Motorcraft Mercon V.
The whole transmission only holds 10 qts. So basically I do have "some" Mercon V in there. Will their additive hurt anything? I'm guessing this additive just makes Mercon into Mercon V?
Thanks,
Brian
Thanks,
Brian
