A anderson Joined Jun 5, 2018 Messages 315 Dec 29, 2018 #1 Question for the mind's here at bitog New to me Passat 1.8t fwd with 335,000 KMS Never has had a trans service. I'm going to be dropping the pan and fluids , should I add lube guard when I refill with pentosin
L Lolvoguy Joined Feb 6, 2014 Messages 3,897 Location Canada Dec 29, 2018 #2 Originally Posted by anderson New to me Passat 1.8t fwd with 335,000 KMS. Never has had a trans service. Whatever you choose, good luck!
M maxdustington Joined Jan 21, 2017 Messages 3,646 Location Worst Case, Ontario Dec 29, 2018 #3 09A right? I think it has an internal strainer that requires disassembly of the trans. I used Maxlife in mine and it definitely improved the shifting. 335k km on FF ATF? Take that, VW haters! Get ready for some tar to drain out!
RooflessVW Joined Dec 24, 2011 Messages 16,069 Location North Carolina Dec 29, 2018 #4 Should be a ZF 5 speed. Good transmission. Lubegard certainly won't hurt anything.
P PPWarrior Joined Dec 16, 2018 Messages 209 Location Texas, USA Dec 29, 2018 #5 If it is a manual transmission, go ahead. If it is an automatic transmission, expect anything...
A anderson Thread starter Joined Jun 5, 2018 Messages 315 Dec 29, 2018 #6 01v trans I believe. It does have a serviceable filter in the pan I'm expecting the worst when I pull that pan. Lube guard will be added to the atf 1 , we'll see how she goes
M maxdustington Joined Jan 21, 2017 Messages 3,646 Location Worst Case, Ontario Dec 29, 2018 #7 My mistake, I thought they were the same trans because I actually got a shift indicator plate from the yard to swap into my car because the Passat and Audi ones are much cooler. Sadly the plate was almost identical save for the wiring.
