This sample is from my Mom's 2002 GMC Yukon Denali. It sees quite a bit of short trips and a few highway miles. The oil was in service for about 8 months and 8000 miles. The oil was Amsoil Series 2000 0W-30. It is the older formula, two reformulations back. I am very worried about the high copper number that has shown up in this oil. Before the change to Amsoil, the engine was very quite and milage was above average. Since the change it has developed piston slap on startup which I originally thought was lifter noise, and the milage has dropped considerably from what it used to be(average of 5 mpg decrease). Any help would be appreciated.
Thanks,
Shane
EQUIPMENT MAKE: GM
EQUIPMENT MODEL: 6.0L 364 CI V-8
FUEL TYPE: Gasoline (Unleaded)
OIL USE INTERVAL: 8000 miles
OIL TYPE & GRADE: Amsoil Series 2000 0W/30
MAKE-UP OIL ADDED: 1.5 qts
SHANE: You mentioned lifter noise, which we would associate with upper-end wear (aluminum). But
copper stuck out like a sore thumb, so maybe that is related to the noise you're hearing. Copper tends
to show wear at a bronze or brass part, like a bushing. All the other metals are okay, but copper
probably shows a problem in your Yukon. No moisture, fuel, or coolant found. The air and oil filters are
working well. The TBN read 2.6, still some active additive remaining. 1.0 is low. We don't know how
long this oil was run but we'd suggest fewer miles on the next fill.
MI/HR ON OIL - 8000
MI/HR ON UNIT - 42000
SAMPLE DATE - 9-28-07
ALUMINUM - 4
CHROMIUM - 1
IRON - 27
COPPER - 184 (NOT A MISPRINT)
LEAD - 7
TIN - 0
MOLYBDENUM - 20
NICKEL - 2
MANGANESE - 1
SILVER - 0
TITANIUM - 0
POTASSIUM - 1
BORON - 23
SILICON - 12
SODIUM - 7
CALCIUM - 3141
MAGNESIUM - 15
PHOSPHORUS - 634
ZINC - 741
BARIUM - 0
TBN - 2.6
SUS
VISCOSITY @ 210 ºF - 60.1
FLASHPOINT IN ºF - 410
FUEL % -
ANTIFREEZE % - 0.0
WATER % - 0.0
INSOLUBLES % - 0.0
Thanks,
Shane
EQUIPMENT MAKE: GM
MI/HR ON OIL - 8000
ALUMINUM - 4
CHROMIUM - 1
IRON - 27
LEAD - 7
TIN - 0
MOLYBDENUM - 20
NICKEL - 2
MANGANESE - 1
SILVER - 0
TITANIUM - 0
POTASSIUM - 1
BORON - 23
SILICON - 12
SODIUM - 7
CALCIUM - 3141
MAGNESIUM - 15
PHOSPHORUS - 634
ZINC - 741
BARIUM - 0
TBN - 2.6
SUS
FUEL % -
ANTIFREEZE % - 0.0
WATER % - 0.0
INSOLUBLES % - 0.0
