Got an '02 Lexus ES300 on my hands, requiring some maintenance. Vehicle's currently approaching the 200,000 km (125,000 mile) mark and comes with the infamous 1MZ-FE, which believe it or not, never had any sludge issues here.
Anyhow, I've put together a list of items and I was wondering if any thing's been missed out, of if there's something in particular that requires attention on this model. List includes:
Pretty sure the brakes need attention as well. But there's also the timing belt replacement. I'm considering replacing the tensioner, water pump and timing belt cover gaskets along with it. Is there anything else that might need replacement with the timing belt out? Thanks!
- Mobil 1 0W-40 and WIX 51348
- ATF (Toyota Type-IV?), gaskets and filter
- Power steering fluid (Dexron III)
- Coolant flush (Toyota pink coolant?)
- Brake fluid (Prestone DOT 3?)
- Denso air filter
- Denso fuel filter (going to be fun to change)
- Denso cabin air filter
- OEM PCV valve
- OEM rad cap and hoses
- OEM Thermostat
- OEM spark plugs
