I just purchased a 00 silverado 5.3L that is taking a few cranks to start. I haven't been driving it yet so I don't have a bunch of details.
The fuel pump fuse kept blowing on him but he insist that it is a fail safe for running to low on fuel (he was broke and only putting a few gallons in at a time). I don't believe it, but who knows?
The fuel gage does not work properly which is typical for these trucks. I checked the fuel regulator and there is no fuel in the vacuum line. I'm leaning toward a bad pump. When the key is turned you can hear a whine coming from the tank. He said the fuel filter has been replaced by the book, but it has been a while since last change. Is it possible the filter is clogged from running on empty all the time?
Any Ideas. Money is tight right now, but I plan on changing the plugs and all filters and doing a ARX treatment. It runs good once it's starts but I need to gets this problem fixed. Would a scan from AutoZone find these type of problems?
Thanks,
Soupy
Thanks,
Soupy
