I have an '00 Audi S4 with 95k miles. Engine is stock (OEM K03 turbos) with the exception of a reflashed ECU.
I drive this car nearly every day to the train station, approximately 2-3 mins one way. Not enough to even budge the temp needle from its resting point. On weekends, it's my "pleasure car" and I drive it normally for errands, short trips, etc. I typically put about 4,500-5,000 miles on a year, and have owned it for the past 3 years.
I have been running M1 0w-40 since I owned it, however I am aware of the sheering to a 30 weight over time common with this oil.
My concerns are:
-Short trips, not enough to warm up engine
-Longevity of turbos/engine
-Proper oil for climate in my area (Philadelphia)
and to a lesser extent:
-cost of oil
-frequency of oil changes
I typically am a "once a year guy" which works out due to the 4,500-5,000 miles I put on the car every year.
I'm game to try Rotella T6 5w-40 next oil change (even though it's not the proper ACEA A3/B3 spec for my engine) - thoughts? Would letting the car "warm up" for 5 mins before leaving help at all? or is it wasteful?
PS. I always use a "good" filter such as MANN, Mahle, or OEM.
My concerns are:
-cost of oil
