who sells this oil?
Well it appears the Wal-Marts in Nebraska and Wisconsin do not stock it. I can't list the web address on this site, but you can order it online from AVLube in Ohio.
AutoZone, AV Lubricants, local Mobil jobber. It's out there, just gotta look around. Any particular reason you want this specific oil? Many syn HDEO's work great in bikes, like Shell Rotella T Syn at WM.
The 'zone has it. Might also try a sporting goods store thats had an automotive department. It's a good oil, spendy though. Ten bucks a quart!
yeah, i own a 1986 V65 magna. at the honda V-4 chat site(http://v4hondabbs.com/index.php?board=5.0), the V-4 guru guy & everyone else highly recommend this oil.
Gold may well be highly recommended for teeth fillings, but siver and solder do just as good for far less cost.
There are plenty of oils on the shelf for $2-$4 qt. that will do just as good of job as the $10 qt oils will.
But then, try telling that to gurus at a Honda board on the internet. (major eyeroll)
Depending on budget...
Shell Rotella T 15W-40
Shell Rotella T Synthetic 5W-40
Mobil 1 Turbo Diesel Truck (Delvac 1) 5W-40
