My vehicle is a 1998 chrsyler concorde 2.7 with 70k on the odometer. It has never gone more then 3000 miles between oil changes and I have ran auto rx twice. I have yet to pick a steady oil. I am low a quart after 1500 miles but do not leak or burn visibly. I was thinking swithing to max life, or motorcraft 5/30 blend. I may try the penzoil platinum. I do not want to leave oil in this engine for much more then 3k or 4k. This is said to be a prime engine for sludge due to poor design PCV system (I replace valve and hose.) Also the water pump is inside the engine which when it starts to weap it causes fast sludge bulid up. (I replace water pump and and timing chain tensioner at 50K). What would you experts due. Cost sometimes is a factor also when I buy oil. Thanks in advance.
