Understand the concept...while there was a key supposition made from the test results, the sophisticated nature of the tests, I believe, sufficiently reduced subjectivity and allowed for empirically-based conclusions.quote:
Originally posted by bruce381:
another thought is when ever I back engine a product I find you can get only so close.
Because an ester "peak" covers a whole lot of esters you need a sample of what you are looking for to see it its in the suspect formulation
called a baseline.
Bruce
