I went to three tire shops that didn't have the correct fit weights for a 17" alloy Ford Explorer Sport rim.quote:
Originally posted by ewetho:
As far as the weights not fitting there are more than just steel or aluminum weights.
We has color coded ones at sears that included
Black - Stick-on weights
Red - Steel Wheel
Yellow - Alot of FORD GM, Chrysler fairly standard alumininum rims
Orange - Larger rim edge width common in Japanese cars
Purple - Chysler wheel weights
Green - Thin rim edges on some *** and european cars
Silver - Truck weights (Not to the semi world yet but heavier stuff like F350s and some thin edgeded aluminum.
So wrong weights SUCK but some shops do not have a proper selection of weights. Heck where I work now does not but covers 99+% of what we do which is FORD!
Just a thought on visual checks which are fairly important if ou find larger problems but a Road Force balancer will check the loaded runout not unloaded which can be more or less than visual. Import as this is how the ires run down the road.
http://imagehost.vendio.com/bin/imageserver.x/00000000/inventexinc/.mids/3528b.jpg
Some of the weights they would put on would fall off and some would stay on which gave me the next day vibration.
Even had a new set of tires installed under warranty.
Stickons didn't do the job.
I had shops Force balance wheels and weights falling off.
Finally had the correct weights installed and things are fine.
Can't believe shops not having correct weights for the best selling SUV,the Explorer.
Although the XLT Sport 17" wheel isn't as common as the 16" wheeled Explorers,still plenty out there.
