Below are all the results of oil analysis from my 2000 VW Jetta TDI. The highlight of this are the 53,000 miles I used Amsoil Series 3000 5w-30 (HDD) with an Amsoil BMK-11 bypass filter, between 46,000 and 99,000 miles. The car was chipped. Notice how quickly I piled on the miles on this car. Most miles were with Flying J or similar truck syop diesel fuel.
The most recent sample was with mostly long trips and almost all high quality Amoco Powerblend 47 cetane diesel. I think I could count the number of cold starts on one hand, so its not suprising the numbers are very good. Not exactly a fair comparison to the Amsoil HDD before.
I will also add that at 120Kmi, one of the HDD 5w-30's biggest critics in the TDI world did a compression test and tested compression values at 550,555,550,545 and noted how spotless the engine was inside.
Regards,
Brian
[ July 13, 2006, 07:56 AM: Message edited by: brian ]
Regards,
Brian
code:
Date 10/7/01 7/26/01 7/6/01 6/10/01 3/10/01 12/26/009/5/00 7/1/2000
Miles Unit 121710 109500 104500 99200 82000 67300 46000 18884
Miles Oil 12086 5000 5000 53000 35800 21100 21600 8500
Oil Brand CAT Amsoil Amsoil Amsoil Amsoil Amsoil Amsoil Mobil
Model DEO AMO HDD HDD HDD HDD HDD Delvac 1
Vis. 5w-40 10w-40 5w-30 5w-30 5w-30 5w-30 5w-30 5w-40
Vis. 100C 14.3 12.2 10.8 13.6 11.1 11.6 11.9 14.9
TBN 8.3 8.5 12.4 12.3 12.1 12.2 11.9 5.9
Fe 15 17 15 43 45 46 66 57
Cr 1 1 1 2 2 2 2 3
Pb 0 3 0 1 1 1 1 1
Cu 1 1 1 3 4 3 5 9
Sn Tin 1 1 0 3 1 1 1 1
Al 5 9 5 10 9 10 12 14
Ni Nickel 0 0 0 1 0 1 1 3
Ag Silver 0 0 0 0 0 0 0 0
Mn Man 1 0 0 1 1 1 1 1
Si Silicon 4 6 3 4 4 5 6 11
B Boron 115 21 59 26 27 22 54 271
Na 0 3 2 0 1 1 1 5
Mg Mag 558 26 16 19 22 24 92 497
Ca Calcium 1994 4387 4351 4388 4339 4364 4319 2289
Ba Barium 0 0 0 0 0 0 0 0
P 1039 1297 1280 1291 1273 1284 1263 1120
Zn 1145 1372 1343 1351 1344 1390 1340 1226
Mo Moly 0 0 0 0 0 0 0 6
Ti Titani 0 0 0 0 0 0 0 0
V Vanadiu 0 0 0 0 0 0 0 0
Cd Cadmium 0 0 0 0 0 0 0 0
Potas
GLYCOL NEG NEG NEG NEG NEG NEG NEG NEG
% H20
%FUEL
%SOLIDS NA TR NA NA NA NA NA NA
%SOOT
%OXD 6.7 27.8
%NOX 8.9 5.7 20 18.6 17.1 12.9 18.6 14.1
