Listed below are my last four analysis results from Dyson Analysis and Holt Cat labs.
2003 VW Golf TDI
Oil Schaeffer's #700 15w-45 blend
Miles on Engine 10246 /20305 / 30211 / 44750
Miles on oil 4770 /10059 / 9906 / 12300
Fuel soot zero /47 / 33 / 42
%Oxid 17% / 22% / 11% / 24%
%Nox 7.50% / 35% / 20.5% / 42%
TBN 6 / 9 / 9.5 / 10.0
FE ppm 18 / 21 / 20 / 14
FE /1k 3.8 / 2.1 / 2.0 / 1.62
Chromium 1 / 1 / 1 / 0
Lead 1 / 3 / 0 / 10
Copper 3 / 3 / 3 / 2
Tin 1 / 1 / 1 / 0
Aluminum 4 / 4 / 5 / 3
Silicon 4 / 3 / 4 / 2
Sodium 3 / 2 / 2 / 4
Potassium 0 / 2 / 0 / 0
Moly 83 / 99 / 112 / 101
Phosphorus 1132 / 1300 / 1425 / 1172
Zinc 1286 / 1416 / 1635 / 1438
Calcium 3272 / 3882 / 4047 / 3770
Magnesium 15 / 18 / 12 / 15
water neg / neg / neg / neg
fuel neg / neg / neg / neg
Antifreeze neg / neg / neg / neg
Starting Vis 14 to 16
Vis@100 13.8 / 15.0 / 14.9 / 15.2
makeup 0 / Oz / Oz / 0oz
additives none -none - LC - LC
fuel treat SS / SS / SS&FP / FP
Filters air/oil oem / oem / oem / Mann
Note: SS = SoyShield FP = Fuel Power LC = Lube Control. 14 ozs were added to the crankcase at 1oz per thousand.
Modifications: EGR adjustment, CCV oil separator, Cat fuel filter added 10000 miles into the period.
Holt Cat: Has no comment.
Lead is elevated however no other wear metals are.
Possible reasons?
I've run the engine harder than I ever have in the past. Running a WOT helps me put the work day behind me and I've wanted to put my work behind me frequently of lately.
Maybe while working on a tractor I transfered some of my lead based antiseize via my hands to the oil fill cap, dipstick, oil filter, drain plug or CCV filter media?
Note: Gap in milage between analysis #3 and #4 is an AutoRx session.
Comments or observations?
2003 VW Golf TDI
Lead 1 / 3 / 0 / 10
Tin 1 / 1 / 1 / 0
Possible reasons?
