Put SF MTL-R in a Subaru manual transmission, and it sure shifts better.
But, I drove it for 5-6 miles and checked the level to make sure I had no leaks/loss, and it sure was foamy. Sounds like I maybe have it too full? I didn't think I did, because I took an identical container to the one the MTL-R came in, and poured the old oil into it, and matched the same volume to put back in the transmission. I guess I'll have to wait until tomorrow to check the level when it isn't foamy in order to get an accurate reading.
Is foam OK in this situation? Thanks for any advice...
