Originally Posted by Triple_Se7en
Originally Posted by rsalan
Originally Posted by AzFireGuy79
I thought research showed a filters efficiency(ability to trap particles) increases with use up to a point. Has to do with pore plugging in the media over time. This is where synthetic media filters like the Fram Ultra excel. If you change it at 5k miles you are gaining nothing and simply throwing away your money.
Is there any data supporting this?
Simple eyeball test is your data. Take a look at all-of the filter dissections in this board room. Most-all filters reach landfills with less than 33-50% fill-rate.
So many here insist on changing filters with each oil change. But would they do it, should that landfill be in their own backyard?
Do you guys not have a recycling facility that takes used oil and filters? My local dump/waste facility has both. I take both and empty my used in oil in big vats that have set up and other bins to toss your used oil filters in.
The filters get crushed/squeezed of oil and the metal, paper, etc is then recycled. Very little like ends up in a landfill. Best of all, they charge zero disposal fees for recycling recyclables. These include paints, solvents, batteries, propane tanks, etc.
http://cleanalliance.com/our-servic...recycling-services/oil-filter-recycling/
http://www.waste-diversion.ca/oilrecycling/
If your city/township doesn't have a place to recycle your oil and filters, and a host of other things, ask why?
