Originally Posted by 53' Stude
Originally Posted by JMJNet
Check this application guide, instead:
https://www.sylvania-automotive.com/apps/vlrg-us/Vlrg/
Hate to break it to you good sir but that guide is wrong or jacked up. I'll use Phillips bulbs from here on out as Phillips bulb was what was in there.
I am not promoting any brand.
I usually just used it for the type, H11, 9006, 9005, 3157, etc.
I believe for the 09 Camry, it points to the correct H11 bulb.
I don't care what brand people buy.
Then there are variants of the same fitting with different numbers because of different watt-age.
I am not sure why you said "jacked up", as far as I know, they did not charge anything.
