Car in question is a 1999 Toyota Solara Manual Transmission. Both lights are not functioning when engaging the reverse gear. What I have done so far:
I took a multimeter to the reverse switch on the transmission. Found no continuity in the switch when in neutral. Shifting reverse completed the circuit and gave me continuity. Is that enough or should I be checking for resistance or voltage?
Both bulbs looked ok. The bulbs had continuity also. I also checked the fuses in the cabin. I couldn’t find a fuse for reverse lights specifically, but I checked them all anyways. I could not find a busted fuse.
Any ideas where I can look next? This is frustrating me. Thanks.
