Marine fuel injection musings
by OVERKILL. 10/19/18 09:45 PM
Finding a new mechanic
by AZjeff. 10/19/18 09:30 PM
Castrol Stop-Start oil
by Silver. 10/19/18 09:13 PM
5.7 vortex Fresh air hose?
by Serolim. 10/19/18 09:11 PM
New Oil Refiner (Frantz) purchased from Ed
by FlyNavyP3. 10/19/18 08:45 PM
1988 Dodge B250 Conversion Van Shocks?
by petes67bird. 10/19/18 08:44 PM
20KW Standby Generator Recommendations
by MParr. 10/19/18 08:15 PM
2003 Diamante, SHU 5W40, 6817m OCI
by Spetz. 10/19/18 07:48 PM
Can you tell a difference between a 305 and 350
by ram_man. 10/19/18 07:45 PM
Changing Fuids
by Snagglefoot. 10/19/18 07:38 PM
Subaru Forester tire pressure?
by Joeescape63. 10/19/18 07:30 PM
PC Duron Synthetic 5W40
by PeterPolyol. 10/19/18 06:43 PM
Shops not willing to do hard work?
by JHZR2. 10/19/18 05:55 PM
Wix 57173, 7400 miles
by JLTD. 10/19/18 05:09 PM
04 Pontiac GP AC Blower or AC Heat Controller
by clarkflower. 10/19/18 04:55 PM
What is Viscosity Index?
by BlakeB. 10/19/18 03:49 PM
Brake Fluid Difference
by Y_K. 10/19/18 02:54 PM
weber auto youtube talking about ATF
by bionictony. 10/19/18 02:30 PM
unreng, lzhome, keninger, Werdage, Frank_C
66249 Registered Users
98 registered members (Ablebody, aquariuscsm, bbhero, Ag76, AZjeff, 8 invisible), 1,448 guests, and 30 spiders.
Topics292,199
Posts4,875,887
Members66,249
Most Online2,494
Oct 17th, 2018
2006 Duramax LBZ, 10k mi, Delvac1 CK-4 #4630123
01/10/18 09:52 AM
01/10/18 09:52 AM
Richmond, VA
DNVDMAX Offline OP
DNVDMAX  Offline OP
Richmond, VA
I've been meaning to post this for a while. Ran my tow tune during last 5,000 miles. Towed occasionally, 5k to 10k lbs.
Code:
MI/HR on Oil			10,019			5,314			15,592			10,746			21,466			13,893
MI/HR on Unit			153,066			148,361			143,047			127,455			106,671			85,205
Sample Date			12/16/17		08/05/17		05/03/17		08/10/14		01/13/14		03/05/12
Oil				Delvac1 ESP CK-4	Delvac1 ESP CK-4	M1 TDT			Rotella T5 		Rotella T6 5w-40	Rotella T6 5w-40
				5W-40			5W-40			5W-40			10w-30
Make Up Oil Added		1 qts			0 qts			0 qts			0 qts			.5 qts (Filter)		0 qts
ALUMINUM			3			3			4			4			6			6
CHROMIUM			<1			<1			2			<1			<1			1
IRON				38			23			47			49			24			34
COPPER				2			1			4			3			4			14
LEAD				2			<1			4			2			1			0
TIN				2			3			3			2			2			3
MOLYBDENUM			45			36			2			3			67			62
NICKEL				<1			<1			4			<1			<1			0
MANGANESE			Not Tested		Not Tested		Not Tested		Not Tested		Not Tested		1
SILVER				<1			<1			<1			<1			<1			0
TITANIUM			<1			<1			<1			<1			<1			0
POTASSIUM			2			2			<1			<1			<5			7
BORON				54			76			43			15			23			38
SILICON				9			7			13			11			6			8
SODIUM				11			1			8			5			10			4
CALCIUM				1262			1212			1354			2517			860			970
MAGNESIUM			961			828			990			50			1171			1258
PHOSPHORUS			1148			981			1185			1091			1070			1098
ZINC				1386			1207			1385			1254			1312			1309
BARIUM				<1			<1			<1			<1			0
SUS Viscosity @ 210F		Not Tested		Not Tested		Not Tested		Not Tested		Not Tested		77.3
cSt Viscosity @ 100C		13.2			13.3			17.0			12.7			15.0			14.84
Flashpoint in F		Not Tested		Not Tested		Not Tested		Not Tested		Not Tested		420
Fuel %				<1			<1			<1			<1			<1			<0.5
Antifreeze %			No			No			No			No			No			0.0
Water %				<0.05			<0.05			<0.05			<0.05			0.07			0.0
Soot %				0.4			0.6			1.6			0.5			0.3			0.1
TBN				8.0			8.8			7.0			6.1			7.2			8.3
06 GMC 2500HD DMAX EFILIVE M1 TDT 5w-40 FRAM Ultra
91 GMC K1500 5.7L 5w-30 Quaker State HM Bosch D+
72 Nova 350 SBC 74mm AirWerks Turbo 15w-40 HDEO
Re: 2006 Duramax LBZ, 10k mi, Delvac1 CK-4 [Re: DNVDMAX] #4630521
01/10/18 02:40 PM
01/10/18 02:40 PM
Fort Lauderdale, FL
DoubleWasp Online content
DoubleWasp  Online Content
Fort Lauderdale, FL
My uneducated observation is that your iron likes to show itself since you switched to T5. Your iron doubled in half the OCI.
Has there been any other changes, such as duty cycle, filter choice, or usage since then around that time?
Re: 2006 Duramax LBZ, 10k mi, Delvac1 CK-4 [Re: DNVDMAX] #4630828
01/10/18 08:21 PM
01/10/18 08:21 PM
Regina, Saskatchewan, Canada
Garak Online content
Garak  Online Content
Looks good. I see the magnesium is still there, and you had plenty reserve TBN.
Plain, simple Garak.
2008 Infiniti G37 - Shell ROTELLA T6 Multi-Vehicle 5w-30, NAPA Gold 7356
Re: 2006 Duramax LBZ, 10k mi, Delvac1 CK-4 [Re: DoubleWasp] #4631110
01/11/18 08:18 AM
01/11/18 08:18 AM
Richmond, VA
DNVDMAX Offline OP
DNVDMAX  Offline OP
Richmond, VA
No real change on the T5 run. Although she was running a tad warm on I-5 in Cali on that run pulling a cargo trailer from Georgia to Cali to Alaska. Mainly used Baldwin filters until recently I experimented with a Wix XP on the previous run and a Fram Ultra on this UOA.
Re: 2006 Duramax LBZ, 10k mi, Delvac1 CK-4 [Re: DNVDMAX] #4632127
01/12/18 06:58 AM
01/12/18 06:58 AM
Indianapolis, IN
dnewton3 Offline
dnewton3  Offline
Indianapolis, IN
Not a bad run. Within normal wear expectations. That's the good news. But, it's a Dmax; "normal" is normal - that's what we expect. What we see here is totally within "normalcy".
I realize this is your UOA in your thread, but I offer this for consideration ...
https://bobistheoilguy.com/forums/ubbthreads.php/topics/4527295#Post4527295
As you can see, I am getting slightly lower wear than you, when Fe wear-rate is averaged.
In contrast, I run dino Rotella 10w-30. All while flogging my 2006 Dmax in heavy towing this last UOA. I assure you you're not running your rig any harder than I did in my last UOA; I was running at/near max EGTs for most all the trip, fighting headwinds pulling my RV for hours on end.
Are you getting "better" results using an expensive syn?
It depends on how you define "better" ....
- You certainly are not getting less wear, that's for sure.
(your last three Mobil syn oil UOAs have given you 3ppm/1k mi, 4ppm/1k mi, 4ppm/1k mi)
(my last four Rotella dino UOAs have given me 2ppm/1k mi, 2ppm/1k mi, 2ppm/1k mi, 3ppm/1k mi)
- You certainly don't need a syn for "cold" starts in most areas.
(these are HPCR injection, with intake grid heaters and glow plugs; starting generally isn't an issue if your batteries are in good shape. My Dmax has started as low as -17F, on dino 10w-30)
You're probably spending 3x more money than I am; what is 3x "better" in your UOAs?
The Dmax engines simply don't care what is in the crankcase, as long as it's an appropriate lube. Base stocks don't matter. Vis does not matter. Brand does not matter. Your UOAs, and others, and mine, just continue to convince me that the Dmax is one of the best wearing light-duty engines made. And they don't need anything special to return excellent results. Syns have not shown any statistical advantage of wear reduction in a Dmax. The lube system design of the Dmax is what controls wear rates; not the base stock or brand of oil.
Yes- this is a challenge to you. It's not meant to be a taunt, but a friendly challenge for you to think outside the synthetic box.
The act of preventative maintenance, in and of itself, is FAR MORE important than brand/grade/base choices among lubes and filters.
- under maintaining something is akin to abuse/neglect; that can kill equipment by shortening the lifespan
- over maintaining something has never been proven to be anything but a waste of time and money
Re: 2006 Duramax LBZ, 10k mi, Delvac1 CK-4 [Re: DNVDMAX] #4632806
01/12/18 07:37 PM
01/12/18 07:37 PM
Michigan
A_Harman Offline
A_Harman  Offline
Michigan
You seem to have had a winner with the Rotella T6 when you went 21k miles and only had 24 ppm of Fe. That seems so good, maybe it was an error at the lab. I think you should do another OCI with RT6.
I'm jealous of your oil consumption. I wish my diesel was that good.
1985 Z51 Corvette track car
2002 Camaro Z28 LS1/6-speed
2001 Dodge Ram 2500 diesel
1972 GMC 1500 shortbed project truck
Re: 2006 Duramax LBZ, 10k mi, Delvac1 CK-4 [Re: DNVDMAX] #4633078
01/12/18 11:41 PM
01/12/18 11:41 PM
Richmond, VA
DNVDMAX Offline OP
DNVDMAX  Offline OP
Richmond, VA
DN3, valid statement on the lack of ROI with synthetics in my application. This is my wifes daily driver and she does jack rabbit starts in the morning, 13..0x sec 1/4 mile times on occasion, and does not let the turbo cool before shutting her down after a hard pull. I guess the synthetics just give me peace of mind so I sleep well at night. I dont think I would run synthetics if I wasnt continuously finding it on sale for $10/gal or less. I have 2.5 gals of T5 in 10w-30 and 15w-40. I will likely run one of these in my next OCI.
Re: 2006 Duramax LBZ, 10k mi, Delvac1 CK-4 [Re: DNVDMAX] #4640567
01/20/18 01:01 AM
01/20/18 01:01 AM
BC, Canada
userfriendly Offline
BC, Canada
Can someone prove that the metals found in used oil are from engine wear?
Re: 2006 Duramax LBZ, 10k mi, Delvac1 CK-4 [Re: DNVDMAX] #4640821
01/20/18 11:19 AM
01/20/18 11:19 AM
Wet side WA
JohnnyJohnson Online content
JohnnyJohnson  Online Content
Wet side WA
userfriendly the best laugh I've had all week with my morning coffee!
2004 Corolla 125400
Out: VML 5w-30 TG4967 OCI 5007 Miles
In: EDGE EP 5W-30 Bosch 3311 122537 7-18-18
2006 Duramax 74277
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 74705 4-22-18
Re: 2006 Duramax LBZ, 10k mi, Delvac1 CK-4 [Re: DNVDMAX] #4691034
03/11/18 01:07 AM
03/11/18 01:07 AM
BC, Canada
BC, Canada
Happy daylight saving time!
Re: 2006 Duramax LBZ, 10k mi, Delvac1 CK-4 [Re: DNVDMAX] #4691036
03/11/18 01:14 AM
03/11/18 01:14 AM
BC, Canada
BC, Canada
Changing the clock make the days longer.
