Hong Kong Cage Homes - This is just nuts!
by StevieC
2 minutes 35 seconds ago
Birthday
by Marco620
25 minutes 19 seconds ago
Lee-Enfield SMLE .303 retirement
by Papa Bear
27 minutes 57 seconds ago
Mobil Delvac 1300. $1.76 a gallon until 8/20
by Gasbuggy
47 minutes 57 seconds ago
Quaker State high mileage 5w30 thus far
by bbhero
Today at 07:32 PM
Oil coolers on trucks
by Snagglefoot
Today at 07:32 PM
RTV drying out
by buck91
Today at 07:27 PM
T6 in Outback 2.5
by countryboy9799
Today at 07:16 PM
LIQUI MOLY TOPTEC 4100 0W40 vs REDLINE 10W40
by g60
Today at 06:56 PM
Lubeguard Platinum for track use on a Z4?
by FlyPenFly
Today at 06:44 PM
Oil temperture before going at it (wot)
by turboaccord1
Today at 06:16 PM
2015 Tahoe - Original OEM
by E39LSMO
Today at 05:51 PM
Christopher Watts
by Zee09
Today at 05:35 PM
Video streaming on Vizio smart TV
by Donald
Today at 04:43 PM
Oil Sump Circulation Throughout Engine
by mbacfp
Today at 04:29 PM
The Limits of RA Bargains on Wiper Blades
by khittner
Today at 04:19 PM
Engine oil cleaning ability vs Oil temperature
by magnus308
Today at 03:24 PM
For Canadians: Mobil 1Turbo Diesel Oil Canadian Tire
by Snagglefoot
Today at 03:15 PM
Old School Tires
by UberArchetype
Today at 03:11 PM
Ford 4.6 oil pump pickup
by FastLane
Today at 02:55 PM
kristrees, PetitFrereArmada, Vlad302, JDUram, gtg
65728 Registered Users
85 registered (ADJ, 5AcresAndAFool, 77GrandPrix, 14Accent, 87sammy, 2009Edge, 14 invisible), 1633 Guests and 31 Spiders online.
65728 Members
67 Forums
288829 Topics
#4577520 - 11/17/17 08:47 PM Any alternatives to using Motorcraft's 80W-90...
JoeJ Offline
Loc: New York
Rear axle lube? This is for my daughters 2008 Ford Escape. It's almost impossible to find Motorcraft 80W-90 Premium rear axle lube where I live. I've heard of additive packages that may not be in other brands of oil. Can I say use Mobil 1 80W-90 synthetic or a Valvoline product?
Joe
#4577529 - 11/17/17 08:54 PM Re: Any alternatives to using Motorcraft's 80W-90... [Re: JoeJ]
Sam_Julier Offline
Loc: Connecticut
Check your local Ford dealer. I'll bet they stock it.
Sam
2005 Highlander 3.3L PC Duron 0W30, 47k
1993 Volvo 245 Delo 10W30, 140k
1993 Volvo 244 Delo 10W30, 152k
#4577545 - 11/17/17 09:11 PM Re: Any alternatives to using Motorcraft's 80W-90... [Re: JoeJ]
Colt45ws Offline
Loc: Central Washington
Nothing special about it. I highly doubt an escape has a limited slip differential. I would just go down to a parts store/walmart/your favorite place to buy oil and buy a name brand 80W90. Castrol, Valvoline, Pennzoil. Whatever is on the shelf and cheap.
Edited by Colt45ws (11/17/17 09:12 PM)
-Colton
2002 Ford Crown Vic PI 207k, Ex-Kootenai County, ID Unit #42
Down for engine swap
2003 Ford Crown Vic PI 75k
Castrol EDGE HM 5W30, Fram XG2
#4577594 - 11/17/17 10:03 PM Re: Any alternatives to using Motorcraft's 80W-90... [Re: JoeJ]
Donald Offline
Loc: Upstate NY
The Motorcraft is nothing special. Walmart or NAPA will have several.
Not sure I would go for Amsoil in an Escape. But you could.
The proper fill level is 3-5 mm below the fill hole.
2015 Ford F250 w/Powerstroke
#4577659 - 11/18/17 12:15 AM Re: Any alternatives to using Motorcraft's 80W-90... [Re: JoeJ]
JoeJ Offline
Loc: New York
Thanks to all for responding! When you say 3-5mm below fill hole what do you base that on? I thought you fill it till the oil runs out of the hole?
Joe
#4577681 - 11/18/17 01:01 AM Re: Any alternatives to using Motorcraft's 80W-90... [Re: JoeJ]
Colt45ws Offline
You can; I dont think it really harms anything. They want it lower because more oil provides more resistance so you lose 0.1% fuel economy.
To figure out the level, use a allen key as a dipstick. Just stick the short end in the hole and dip it in the oil. 3-5mm is around 1/8 inch.
-Colton
#4577714 - 11/18/17 03:10 AM Re: Any alternatives to using Motorcraft's 80W-90... [Re: JoeJ]
Happy Birthday Marco620 Online   happy
Loc: Kansan,1911 45ACP fan
Excellent advice Colt45ws. In a class I took, you need to fill to the point where sticking your pinky finger in you can feel it on you pad of pinky.
2015 Civic 175k mi.0w20 Redline/Archoil9100,HPS SRI,Yokohama/Borla Exhaust/Tein Suspension/Fu7317/Redline Si-1
Go Nashville Predators!
#4577718 - 11/18/17 03:45 AM Re: Any alternatives to using Motorcraft's 80W-90... [Re: JoeJ]
mattwithcats Offline
Loc: Virginia
2009 Smart Pure
Pennzoil Platinum Euro 0W-40, Purolator Synthetic PSL 14610, 45 mpg...
185/55R15 General HP tires, "H" speed rated, 44 psi (300 kpa)
#4577721 - 11/18/17 03:55 AM Re: Any alternatives to using Motorcraft's 80W-90... [Re: JoeJ]
Lubener Offline
Loc: N.Ohio
Just fill it to the bottom of the hole. No science here and use any 80-w-90 GL5 lube. There is nothing special about Motorcraft unless you ask the dealer parts guy.
Edited by Lubener (11/18/17 03:57 AM)
The "thinking" man's friend.
#4577759 - 11/18/17 06:18 AM Re: Any alternatives to using Motorcraft's 80W-90... [Re: JoeJ]
JoeJ Offline
Loc: New York
Thank You All! Colt 45 that allen key trick is great. I was wondering how to measure it. I'm going to go with Lucas 80W-90 gear oil. It is an GL-5 oil that meets or exceeds Fords specs.
Joe
#4577774 - 11/18/17 07:00 AM Re: Any alternatives to using Motorcraft's 80W-90... [Re: JoeJ]
2015_PSD Offline
Loc: SE Texas
Most AZ, AAP, OR, or Napa stores will have M1 75W-90 on the shelf fairly cheap if you want a synthetic. Walmart usually has a few brands of 75W-90 synthetic or 80W-90 conventional for a good price.
2018 MB AMG GLC43 3.0L Coupe - Castrol 0W-40/Purflux
2018 MB C300 2.0L - M1 0W-40/OEM
2015 F-250 6.7L PS Diesel - Delo 15W-40/CQ Blue
2014 Explorer 3.5L Limited - M1 AFE 0W-20/FU
#4579081 - 11/19/17 03:08 PM Re: Any alternatives to using Motorcraft's 80W-90... [Re: JoeJ]
Piston_slap Offline
Loc: Va.
I'm told some of the expert posters on here use their x-ray vision to verify levels and their pinky can perform chemical analysis! LOL
1994 Ford Econoline w/302 & 4R70W
Valvoline 10W-40, Motorcraft FL1
Isotope U235
