I don't think you should take one internet diagnosis as gospel. If the wheel bearing is shot the brake rotor will shake with the rim but the caliper bracket and knuckle WON'T, and the pads will bounce around not really knowing what to do.
If your bearing is tight but you have bad control arm bushings, ball joints, tie rod ends etc the steering knuckle will shake with the wheel and brakes.
But you've got something going on!
