Awhile ago I had a post about this but I recently got more information and the last post kinda veered in a different direction so I figured I'd start a new one. I'm having an issue with my hub wobbling on an AAM 10.5 (14 bolt). I have it stripped down to just the hub. I am getting .010 run out when I spin the hub. If I take the axle shaft out I get hardly any runout. I thought maybe the axle shaft was bent causing the problem. So I have a spare axle I can use for parts so I put that axle shaft in and I get the same .010. Does anyone have any more ideas on what to check? I don't think a bent spindle would cause this. I have already tried a different complete hub with bearings. I'm thinking it's causing a vibration or shake while driving because I've had multiple sets of tires and wheels in it and it seems to always have the same shake. Thanks for any input.
