Originally Posted By: JHZR2
I'm not a big believer in an all in one CLP. None of us particularly need to worry about living autonomously in the field for days/weeks/months, with limited amounts of stuffed can carry.
Ballistol is relatively good because it does clean, it does protect against corrosion, and it does lubricate. It's also relatively safe on wood, and non toxic for parts to be readily handled.
There are relatively better oils and greases for high friction/high wear points. Other than a few odd spots, ballistol has worked fine for corrosion protection. It also works well enough as an interim cleaner, as I'm not keen on running brushes too often, or strong solvents. A few patches with ballistol (sometimes following a first patch with hopped elite or butch's bore solvent) works great and leaves behind a protective film.
I like ballistol for what it is. I also use it to coat hand tools that are prone to surface rust. Works great there too, and zero concerns regarding subsequent skin contact.
These are MUCH BETTER products out there that work as good or better.
