Originally Posted By: 14Accent
Don't switch back and forth between E-85 and gasoline on back to back tanks. It takes the alcohol sensor and PCM a long time to adjust to E-85. However, if you wanted to run E-85 for say... a month and then switch back to gasoline you could. I would almost advise doing it in stages:
Run tank to 1/2, top off with E-85. Repeat. Then do the same in reverse when switching back.
Would resetting the ECM (via battery disconnect) alleviate the need to do what you've recommended? The ECM should clear learned tables and look to learn and repopulate quickly.
Even if the ECM isn't reset, the AFR will go wonky quickly and the ECM is likely designed to recognize the cause and adjust, right?
