Originally Posted By: d00df00d
- If a passenger vehicle needs wheels bigger than 17" to look right, it's too big; and
- If it needs brakes that wouldn't fit under a 17" wheel, it's too heavy.
Speed is a much bigger factor requiring bigger brakes than weight. Kinetic energy is related to the velocity to the forth power, while weight is a linear relationship. Small increases in speed require a big increase in brake thermal mass required. Maybe you need to drive faster cars? (I keed, I keed)
This is why vehicles designed to run on the autobahns typically have large brakes. The rear brakes on my 1er are about the same size as the front brakes on a new MDX, it is about speed, not weight.
KE = 1/2 m v^2. Kinetic energy is proportional to velocity to the second power, not the fourth. Were you thinking of wind resistance, perhaps?
Either way, yes speed is a bigger deal, but we're not talking about race use here. This is for public roads, where the high end of the speed range (say, the 90th percentile) is more or less the same for most cars in most contexts. Mass may represent a smaller part of the equation than velocity does, but it accounts for most of the variation.
Also... don't your 1er's brakes fit under 17" wheels?
They can fit under some 17's, but not many. The front brakes are REALLY tight on the OE winter 17's. I think the only reason they do fit is because they used 6 pot front calipers that barely stick out further than the diameter of the rotor.
Sorry, not sure why I wrote forth power, thank you for the correction above.
