Originally Posted By: SR5
I'm a 36 psi guy and maybe a touch more in the spare.
Found this (Note: it's from Australia so "Utility" means "Pick Up")
Quote:
Small Vehicles
Car Type : Pressure Range : Optimal Pressure
Standard : 30 - 36 Psi : 32 Psi
Sports : 32 - 38 Psi : 36 Psi
Wagon : 32 - 40 Psi : 38 Psi
Utility : 32 - 40 Psi : 36 Psi
Medium Vehicles
Car Type : Pressure Range: Optimal Pressure
Standard : 32 - 40 Psi : 36 Psi
Sports Car : 34 - 42 Psi : 40 Psi
Wagon : 34 - 40 Psi : 38 Psi
Utility : 32 - 44 Psi : 40 Psi
Large Vehicles
Standard : 36 - 42 Psi : 38 Psi
Sports : 36 - 50 Psi : 44 Psi
Wagon : 38 - 46 Psi : 42 Psi
Utility : 40 - 50 Psi : 44 Psi
Here
http://www.ozzytyres.com.au/blog/what-is-the-ideal-tyre-pressure/
SR5,
Thanks for that chart. I hope everyone will understand now that even tire dealers don't know what they are talking about - and they publish stuff that contradicts what the vehicle and tire manufacturers say - further confusing the issue.
The vehicle manufacturers specify the inflation pressure - and they use a variety of methods to arrive at it. In the old days, they frequently picked the smallest tire that would carry the load - hence the 32 psi in the bias tire era.
However, it was discovered that you could get a better ride using a larger tire, but less pressure. It was also discovered that the vehicle behaved more predictably when using larger tires. (short version: Tires operated near the max load/max pressure point would sometimes have large curves in the tire force and moment diagrams. These are flatter when using large tires, even at lower pressures!)
Nowadays there isn't a simple formula that every vehicle manufacturer uses to select a tire size and inflation pressure. For example GM
TENDS towards using 30 psi for their cars and 35 psi for P metric tires on SUV's, trucks, and vans - BUT not always!
That's why Tire Guides publishes a book summarizing not only what tire size came on vehicles, but the specified pressure, the rim width, lug nut torque, etc. It gets updated every year - published about January or so!
So I always say: LOOK AT THE VEHICLE TIRE PLACARD! If nothing else, it ought to be a clue where to start. And since 2008, (in the US) it's supposed to be on the drivers door or doorframe!
