Originally Posted By: clinebarger
Originally Posted By: joegreen
would this ring gear work even though its from a 67? http://www.ebay.com/itm/67-rear-ring-gear-th400-transmission-oldsmobile-/172227839411?hash=item28199445b3:g:zSQAAOSw9eVXUFKr&vxp=mtr
Yes, It will work IF your carrier pinions are Helical Cut, If you have Straight Cut pinions it will not fit. What is wrong with your ring gear?
The ring gear is fine but where the ring gear goes into the output shaft bushing the surface is all scored where the bushing would ride. so i figured i needed another ring gear with a good bushing bearing surface. did you see my other post above this one you quoted?
